Bustedknuckle
I pulled this from my 2003 BF200, I hooked up the white wire(heater) up to the pos and neg to a fully charged spare battery and it was hooked up throughout the whole test on the video below. Then I hooked up the gray and black wires to my volt meter.
Voltmeter setting on 20 = the voltage shown on the video.
resistance test on the heater wires with OHM setting at 20k = .001 reading
https://www.youtube.com/watch?v=_8I5N8plnMY
The o2 sensor would heat up to about 150 degree externally but no more, when I applied heat the voltage went up.
MY BIGGEST QUESTION: Is the O2 sensor heater suppose to heat the O2 sensor to 600 degrees?
My thought is the O2 sensor heater is not warming up to the operating temperature of 600 degrees as the voltage was within the range when the heat was applied. I know the signal wire works but thats powered by my heat source not the exhaust.
