I have an issue with my 03 Honda 200s. The outboard idled a little rough and turns off at times when going back into neutral.. With in the last 60 hours I have new plugs, hp and low pressure filters, new fuel pump..most recently I did SB56, but put a donor O2 sensor that was supposed to be good.. Anyways, I took boat out over weekend and after a 26 mile run, I was idling and I started to get a beep on-off-on-off, etc. I checked codes today doing the shunt and I got "1" light on and off, on and off..So is it my O2 sensor? I do also want to add that on my return back into port my rpms would only hit 3000 and seemed to lack power..Would this all be related to O2?
