ship wreck
I pulled the 140 I've been fighting with for the past two seasons and tore it apart today. I was advised that the compression was a bit low and it was getting lower so I figured I needed to open it up. My hope was to do a refresh but I found it ingested something and needs a new piston and cylinder bored. The head I believe will clean up but if not that adds to the cost. Everything else in the motor checks. Crank measures spot on. Other cylinders are in spec no issues other than needing rings.
So choices are:
A rebuilt power head that runs 1500 to 2500 depending on the source and maybe a bit more if there is a core issue.
A rebuild kit which is around 900 plus machine work and a marine machine shop is not easy to find here.
Or purchase a boat locally for 1000 that has a 135 starflight.
This last option has all the pitfalls that got me to where I am with this Johnson as I bought it with a boat as well but I only compression tested it never ran it in the water My thought is if I can lake test the local boat that should tell me I have a good motor but you never know what might happen down the road.
Suggestions?
So choices are:
Suggestions?
