bumper1990
OK guys here's my situation I bought a 68 Johnson 40hp seahorse 2years ago it runs like brand new looks brand new and worked very well for me the first year due to lack of storage though I had to keep it outside with a tarp over it. It worked fine when parked. Went to start it this past summer and it wouldn't turnover so I checked the starter that was working fine so after some turning on the flywheel with a wrench and turning the prop by hand I got it freed up and it cranked right over and fired up put it in gear (automatic) and prop spun put it in neutral and it stopped no problem but I noticed a tiny crack in the lower gearcase....no oil in the lower unit so I put 75-90in (I was told to run that) felt confident and took it on the river went about 300yards up stream no problem then just lost movement the motor just screamed the prop still spun just under load it won't move so I coasted it 8miles back down stream (missed the launch pad cuzz it was high water and I had no power) and took it home called a few boat shops one said to run straight 90weight in it and another said I had to use regular Johnson evinrude blend oil because of the automatic shift and clutches did not try either yet got busy and if that's not the problem I know I'm gonna have another nice float ahead of me now from what I've gathered it could be a spun prop but that doesn't make sense cuzz of the lower unit being stuck and I thought it was a dog clutch in the lower unit so idk how that would do it any suggestion I'm all ears and need help
