aristakat
Ok all need imput again : port motor honda 225 yr 2002,,, died as running idle from one spot to next brought to mechanic to trouble shoot. check fuel from tank to motor,I replaced hp filter,racor inline filter, replaced squeeze primer bulb.... had fuel coming from tank to motor pulled line to ensure fuel coming out of hose when pushing primer bulb.... Checked to hear fuel pump enigize it did fuel comes out of hp pump , drain hp pump to enusre not blocked... switched computer on side of motor to other side to see if problem would siwtch to other motor by switching computer... nothing.. spend countless hours motor started felt by messing with electrical plugs might have effected iy positively only to find out next day died again while idiling out.. motor seems like no fuel pressure fuel bulb goes soft we pump solid stills solid but motor doesnt start... Able to spray starter fluid in air vent motor will run untill fluid burns off.. diffently starving for fuel ... could it be fuel pump hooked to a honda diganotic tool no codes thrown ??????frustrating straving for fuel why ? maybe harness not firing pump ? any ideas ... thanks in advance Jamie
