"No worries, I'm just as i
"No worries, I'm just as ignorant in many areas...
Which is what brought me here in the first place...
Yes, water comes up through the vents in the base, which is the water pump inlet. The water pump sits on the lower unit inside and pushes water up a tube inside of the mid section (exhaust housing), into the engine. From there it branches, a portion goes straight to the pee hole, and another to the thermostat where it goes into the engine block once it gets hot enough. Most of the water is exhausted with the exhaust. The pee hole is just an indication if the pump is working or not.
Here's a good link describing how your cooling system work. And, heh, it says in cold water, pee hole freezeup is common.
http://www.ankn.uaf.edu/publications/VS/cooling.html
I'd just shoot some WD-40 straight into the pee hole then chase it with a piece of wire. If it's ice, WD-40 alone will probably do the trick.
If that doesn't fix it, you might have a water pump problem. If you can locate where the water line enters the intake manifold (where the thermostat is just downstream of the carb), you can disconnect it there, fire up the engine for about 10 seconds, and see if you get flow. If not, then you might have a bad impeller.
If you tilt you motor after use, it's possible that about 1 tablespoon of water can collect on the inlet side of the pump... and it's possible that that could freeze, binding up your impeller. But I would think that it'd probably be pretty tough to start if the shaft was bound up, unless if the impeller just sheared off. I don't really know if they can fail that way. But if you had hard starting before it lit off, that might explain it.
This happens because there is no drain hole right there, whereas everywhere else water drains out of the engine when you tilt it.
Water pumps aren't hard to replace. You've just got to remove the lower unit. Disconnecting the shift rod is the most difficult part... everything else just slides out. if you get to that point, I can help you with the step by step.
Personally, I'm putting my money on ice in the pee hole, in which case, you probably don't have a problem. Since it's a 2007 engine, I'd be surprised if it's anything else."
