cnewton700
Have an 84 Mercruiser 5.7L 260 sterndrive. It was running rough I pulled the distributor cap and found the contacts covered with green corosion, the rotor contact was black and rusted to the shaft. Had to cut it off. The connections on the coil were also badly coroded. So I replaced the cap, rotor and coil. It started up easier and idled better but shortly started backfiring and when shifting gears it would die. Within an hour it died while idling and would not re-start. No spark being generated by the coil. Testing shows the coil receiving correctly. A test light on the pos and neg coil terminals flashed on and off when cranking over so I assume it's receiving the order to fire but there is no spark at all leaving the coil. Could a new coil have gone bad that soon.
