"Hi, I need some help on my 19
"Hi, I need some help on my 1973 Johnson 135hp,I took her out to the lake and she would turn over but not fire.Found out there was no spark on all 4 cyl.I thought it might be the stator so I took it to an alternator shop to see if they could rebuild it.They called me back and said everything checked out to be ok and there was no problem with it,so I put it back on.I just purchased a multimeter and im not sure of the easiest way to troubleshoot the powerpack or whatever else it might be with the test meter.Also,before I took the stator off there was a very weak intermittent electric current (but no spark)running through one of the spark plug wires,but none on the other 3.If anyone could help me pin point the problem i would appreciate it,thanks."
