Fishingfool001
Hi all, new to the form. Recently bought a boat with an 1986 70hp Johnson 2 stroke. J70ELCD. First time taking her out motor started and ran perfectly fine. Got stuck toward the end of the day due to bad batteries . I replaced the batteries to 800 cca and good to go for the 2nd trip.
However before my 3rd trip the motor wouldn't fire at 5am, roughly 55 degrees out. Later that day I tried again, coughed, then started right up 85 degrees out.
Work done
New plugs+wires champion .03 gap
New Stator cdi
New power pack cdi
Clean carbs
To this day, months later I still have the same issue, motor won't start when in cold temperatures, no spark at all. But when it is warm outside she fires right up.
Flywheel spins like no other. I disconnected the rectifier still nothing, disconnected kill switch nada. Seems like no matter what I do she wont fire in the cold.
I run the engine with muffs at least once a week after work (80+ degrees out). But stumped when I get nothing in the colder mornings.
Any help would be greatly appreciated.
Work done
New Stator cdi
New power pack cdi
Clean carbs
