realcaptron
Why not swap modules between the two engines? That should prove if it is the module or not, unless they are specific to engine rotation.
erich.....not a bad suggestion, but at this point I am afraid to risk blowing another one. FYI i did swap them last week when I first encountered the no spark issue on the starboard side, and the one in question fired up the other motor just fine. I did not check timing on that module however while it was swapped. Reminder to all of my helpers here, this is on the counter rotating starboard side. The balancer turning counter clockwise when viewed from front of engine, resulting in advanced timing mark coming up on the right hand side of timing tab, as opposed to coming up on left hand side of tab on the port (standard rotation) motor when viewed from the front.
Throwing this out there for further consideration....prior to the stalled engine, no spark event....I had over ridden the base timing with shunt because it was not advancing enough by running it up to 2500 rpm and advancing the distributor to obtain 28* advance at that speed. This action resulted in an idle speed timing of more than 12* advance WITHOUT the shunt. In speaking with the technician at the place where I bought the Delcos a couple months ago, he told me that 12* advance at idle was excessive, and he stated that condition could in itself cause a no spark issue. He advised me to retard the distributor a bit to see if that cured my problem, which it did not. As I reported, it turned out to be a loose run wire under the helm. So now the engines are running again, but I am not seeing the advance on that starboard motor that I think I should be seeing.
