No power when in water
GavOz
115 Johnson outboard motor model 115ML78C - this motor is truly baffling us! Total engine rebuild been done, running full power with muffs on but as soon as in water - no power and runs rich. It seems like the motor exhaust gases cannot escape? have checked exhaust outlet - appears to be fine. All clear, is there something we are missing? Or need to investigate further?
Any ideas would be helpful.
Thanks Gav
Australia
How did you TEST full power on muffs ??-------It can sound really good to you running on only 2 cylinders and it will roar.----------Test for spark on all leads.--------------Check to make sure the orange wires from powerpacks are going to the correct coils.---------You did install a new diaphragm in the fuel pump I hope.
