decker5484
Ok fellow boaters. I am fairly new to being a boat owner and try to do small repairs myself. In fact, I changed the oil in my upper and lower unit myself (so I thought). I was told to remove the lower plug and then the middle plug to let the oil drain. I let it drip dry for about 2 hours. Once the unit was drained, I filled it from the bottom with my pump until oil came out the middle plug. I then sealed it all back up. A few days later, I took the boat out and ran it for about 5 minutes when I started hearing a howling noise coming from the outdrive area. I turned the boat around and trailered it back up. When I got home, I pulled the top cover off the outdrive (where the oil dipstick is) to find the upper gear case bone dry of oil. I thought the upper unit was separate from the lower unit and they had to be filled separately. Apparently I made a costly mistake.
After I realized there was no oil in the upper unit, I pulled out my Seloc manual and realized you are supposed to fill from the middle plug which fills both the lower AND upper unit at the same time. You then check the level with the dip stick. Duh, this makes total sense now.
When I look inside the gear case where the two gears are, I notice quite a bit of metallic dust on the sidewalls and the bearings. Upon inspecting the gears themselves, they are visibly worn. There aren't any big chucks missing, but they are definitely worn a bit.
My question is this: Can I still run the boat like this if I fill the upper gear case with oil? They obviously need to be replaced, but are they salvageable for awhile? My guess is no because of the metallic dust everywhere which will eventually wear the gears and bearings out completely. Thoughts???
