No Fuel
jimhammond
I have a 2007 Honda 225 with about 1800 hours. I am having a problem with the fuel system. Here it is. Start the engine first time and go to destination, everything is fine. Shut motor off, fish a while, start motor, put it in gear and proceed to get up on plane. At this point, the motor starts to starve for fuel and begins shut off. If I turn it off and pump the bub, it will start and run fine until next time, I shut it off and it does this almost each time. I have replaced the bulb, fitting on the tank, filter under the cowling and fuel line from the tank to motor. Any suggestions
Jim
[email protected]
Any alarms or lights on the key switch panel? If not, I would proceed as follows:
1. Clean/replace low pressure fuel filter.
2. Drain the VST.
3. Replace HP fuel filter.
Okay, then you need to pull your fault codes by shunting the green/white wire to the black wire on your service connector - that is the red four-prong connector under your electrical panel cover on the front of your engine. The procedure has been described many times on this forum. If you need help, send me an e-mail at [email protected]. BTW - you should have the four-light panel on the 225.
