All,
I've recently purchased a boat with an Evinrude Vindicator 200hp outboard SR# E200CXEC. The engine was firing and running really well at the time of purchase. I've set the Boat up for the winter and decided to give it a start this past weekend. However, when starting the engine I got nothing. Checked for spark with gap checker and no spark on any cylinder. I began to diagnose the symptoms and test backwards by unplugging the kill switch and shift switch, still no spark. I then checked the stator with volt meter for resistance. (brwn to brwn/yellow wire was 776 res) Even though this is low according to spec. Would this cause a "No Fire" condition? How do I check the power pack? How do I check the Rectifier/Regulator? Would bad Rectifier/Regulator cause no spark condition?
Also, I am getting gas to the carbs. Even sprayed a little choke spray into each cylinder to see if it was gas restricted. Still no Start/No Fire.
Thanks in advance
Thanks in advance
