"Ok I checked that last night
"Ok I checked that last night and thats only one of things I noticed . I aslo found that the bolt that holds the bracket or thing that the throttle cable on , the threads have been stripped out and it will not tight up completely. I started to use my tap and die and just rethread it but want ed to get more suggestions . may be this is why the throttle will not open up all the . Also the spring inside the lever does not pull the timer base thing all the way to down .making me feel that the loose bolt is t blame or the spring needs to bee replaced.what do you guys think?"
