Picked up a 2002 Nissan 5 HP 4-Stroke (NSF5A2) and trying to resurrect it. It has good spark but low compression (25 PSI cold). I put some oil in the cylinder and the compression increased to 50 PSI - still way low. It will pop a few times after I inject the oil into the cylinder. Checked the valves and they had the proper clearance. Pulled the lower unit and injected air into the water tube and no air came out through the spark plug hole. Thus, I think
the head gasket is OK? I think
the problem is worn rings? Drained the oil and there was no water in it. Lots of black soot on the driveshaft. I was going to disassemble the power head (if I don't break off too many bolts) and look and the cylinder walls and if OK replace the rings. It is a salt water motor so it may have to be turned into a parts motor which I hate to do
. Anything I missed here?? Suggestions?? Thanks .................
