Nevada Mike
I have done some searching and will do more. Thanks to all of you that have posted great information. I have a BF200 with about 400 hours on it. The only problem I have ever had was a sputtering engine for about 30 seconds until throttle reached the mid point. It only did that once with no alarms or lights. Any thoughts? I was a little nervous because I was over an hour from the dock. So far my maintenance has been limited to Oil changes and changing the Racor each season. I will be going back up to the cabin in November and getting after all maintenance items that I can complete. I did not have time to do any maintenance this year when I put it away other than a flush with salt away. Sadly I can not practically get it to a regular Honda shop or I would. Would someone mind listing items they would consider at the 400 hour mark. I am considering the following list.
Oil and filter
Lower unit oil
High and low pressure filters along with the Racor
T stats
Impeller ( should I get the large kit or just the impeller?)
Thanks for any comments or suggestions on my list. I freely admit I have more searching to do here. I just found this forum today.
Oil and filter
Lower unit oil
T stats
