Hi all,
I just joined the forum after picking up a new to me 14' Lund. I also picked up my brothers B100-1000179 10hp motor. He purchased it used some time in the 90's. The guy he bought it from had only used it as a kicker. My brother used the motor as his primary motor on his 14' aluminum until sometime in the late 90's. It then sat in storage for the better part of a decade with no use. It also had not been serviced before it was put away.
It's surprisingly clean on the inside, though it could use some love.
I pulled the plugs and both looked like this:
I hit them with the wire brush to clean them up before trying to get the motor started. After nearly pulling my arm off with no results, I figured I'd try turn the On/Off switch to Off and see if that made any difference. It sputtered and started, then died. After a few more pulls it fired up. It actually runs pretty good considering it's been sitting for so long.
I ran the engine for about 5 minutes. I've since changed the oil, gear oil and gapped the plugs to .028. It's running good, but seems to be a bit on the high side for an idle. I think it may also be running a bit rich.
I am having a bit of an issue with the starter making a "tinging" noise when I go above 3/4 throttle. It goes away when I go below 1/2 throttle and give the pull cord a short 2-3" pull. Any suggestions on how to fix this? Any tips on general maintenance?
Neil
Neil
