Hi guys, I just decided to test my ignition coil's primary and secondary resistance values. I have a BF100 with the serial no. that shows my coil is 30500-881-004. I emailed Honda and they sent me a document stating that the primary is 0.56 ohms +/- 10% and secondary is 8k +/- 20%.
I took my reading with 3 different meters to compare. My primary came out to be 1.5 ohms and the secondary is 33.1 k ohms. As you can see, these values do not match and are too high. When I read about and talk to people concerning these values they talk about getting readings that are too low and how this can affect the running of the engine. However, no one mentioned anything about getting values that are too high.
Does anyone know why I would get too high of a reading, short of using the meter wrong? As you can see, they are about 3x as high. Since the meter changes by a factor of 10 when you turn the knob, then the 1.5 could really be 0.15 ohms and the 33.1 could be 3.1K ohms meaning that my values are way to low and perhaps part of my problem. However I can not seem to register those values on any of the settings.
Thoughts are welcomed,
Mike
Mike
