Need help
EricC
I Have a harness to fit a 2000 90hp Johnson ocean pro, I don’t know what plugs go to from ignition to the motor need someone to help me to connect all of it up from start to finish
most of the plugs on most models only fit in one spot. it's as simple as counting the pins to match them. you can't really mess it up. just start on one end and unplug and replug the new harness on to the engine one plug at a time. it's just tedious and you have the blessing of taking a picture of them all before you start.
Should be just a plug and play set up extremely simple. pretty much idiot proof
Thanks for reply yea it may be pretty much idiot proof but when motor is on a stand and parts are in a plastic bag ? it’s a bit confusing to me when you don’t know anything about this motor as on my boat is just a 70 hp, and I think there’s some bits missing ? Like the box to control tilt/trim and two wires cut on ignition, half of forward control box , all I have on that part is leaver, cables already on the leaver ? that’s why I’m trying to find out if I need any parts to get going while it’s on stand before I swap motors over thanks Eric
This is motor I got and other is the parts I got with trying to work out to connect to try to start hopefully u can see the connections properly, sorry everyone for not sending photos before as I’m new to all this think I should have checked out everything before I bought?
