I have a Honda 130A (2001) that is leaking fluid from a seal located in the power tilt trim area. I first thought it was a sea star steering cylinder leaking and the fluid was running down the engine but after a closer inspection there appears to be a seal in the power tilt trim area with a reservoir just to the right of it which looks like it has a place to add fluid.
What kind of fluid does it take? Is there a repair kit similiar to the seal repair kit that sea star makes that comes with a special spanner wrench? The motor will still raise and lower but it is loosing some fluid, enough that there was a small trace on the ground below the engine. Thanks in advance for your inputs.
