Clearing Fault Codes (From Honda Dude)
Essentially,to clear the codes, you operate the kill switch 5 times with the shunt (shortingdevice, or paper clip) in place and within 20 seconds of the key switch beingon.
Irecommend grabbing the safety lanyard very close to the switch that it isattached to so you can pull it to off and push it to on without losing thelanyard.
· Connectthe shunting device (technical term for paper clip.)
· Turnon the key switch.
· Pullthe safety switch to off, then push to on, then pull to off, then push to on,then pull to off, then push to on, then pull to off, then push to on, then pullto off. That should be five times off and on and off within 20 seconds fromwhen you turn the key switch to on. When you get to the fifth time off...youshould hear one or two beeps. The codes are clear. If you did not hear thebeeps, try again.
· Turnthe key switch off
Removethe shunting device and run the engine. Then check for codes again. If all isclear, you may just have had a onetime occurrence. If you do have codes, youwill just have to troubleshoot depending on the code number that you get.
