Ive got a 2006 Johnson 115 mod J115GLSDE ser 05148390 with an outboard jet pump. Ive been getting a hot alarm at idle in the water just sitting at the boat ramp. proceded to change water pump impeller thinking that was the obvious problem. Now i still have a strong tell tail warm but not hot. Still getting alarm at idle. Ive been fighting this problem all last summer. I've flushed cooling jackets changed both thermostats both temp sensors even though sensors checked ok. Changed plugs, wires, coil packs even change tac in case problem was in that. Sitting in the driveway with hose hooked up it will run fine with no alarm but in the water it still goes off. I attached thermocouple on my fluke, heads were running around 87 F degrees after 10 minutes of idling. Now starting to look into VRO fuel oil system. At this point I'm lost and tired of throwing parts at the issue. Any advice would be appreciated. Thank you.
