Even tho it should be an easy fix, it is more complicated than a simple starter solenoid "old style" circuit.
The complicating factor is the presence of a start delay relay. These circuits are controlled by the EMM.
In order to turn a circuit ON, the EMM switches the GROUND lead to actual GROUND internally when the circuit needs to be activated.
In this case, the yellow/red wire from the keyswitch goes to the start delay relay. Normally, on old style starter circuit, it would go to the starter solenoid.
(In my first post, I was wrong on the wire color at the solenoid to look for.)
The start delay relay is activated or energized by the EMM, after the EMM determines everything is go for start.
The EMM switches the ground lead of the start delay relay to actual GROUND internally, and allows the start delay relay to pick, and then the actual starter solenoid can pick.
That pick wire color is yellow/blue, NOT yellow/red as I posted earlier.
And, to further complicate...the starter solenoid GROUND is also controlled by the EMM on that pink/white wire off the solenoid.
If you want to debug these circuits, you must get a good color wiring diagram.
Be aware that the only part of this whole starting circuit that goes thru the PDP is the ground leg of the start delay relay. One wire. BROWN.
It also controls the ground for the HP fuel pump. Another symptom of your problem COULD BE that the HP fuel pump is also not operating.
Gotta get a diagram, and be good with a meter.
ALSO, there is a known fault within the EMM known as the "three finger salute" when three lights on the tach come on and stay on when you turn the key to ON.
If that is the case, the EMM is faulty, and one of the symptoms will be NO START, and NO FUEL PUMP.
