fishschticks
Bought a used skiff in Southern CA with a 60hp Honda. Engine ran great during pre-purchase test run. Next trip, cruising the harbor at low speed went perfect. On a later trip (also cruising) the engine cut out at low speed (possibly partially due to a closed tank vent), and the check engine light came on—no overheat warning. Pulled the code by shorting pins as described on other forums: 8 short, 4 long blinks (starts with 1 blink, repeats).
My mechanic serviced the engine (recent $6k rebuild prior to purchase), replaced a nearly clogged high-pressure fuel filter, changed oil (level was high), gear oil, impeller, and fuel/water separator filter. Engine now runs well when it starts, but still hard to start and check engine light remains (tried to clear it, didn’t seem to work as I got no blinks when doing so). New tank and gas installed. Starts with throttle, struggles without.
TLDR; Looking for help identifying the 8 short, 4 long code on a 2015 BFP60A, and advice on other possible causes (e.g., sensors, spark plugs, thermostat) since the code isn’t clear, I have no access to code reader/pc/shop manual (long wait times in high season) and starting is still difficult.
