It is 2003 Honda BFD15 carburetor manual outboard motor, I bought it two years ago. It just needs 1 pull for cold start, but it needs more than 10 pulls for warm start. If I unplug the connector from fuel tank 10 seconds before shutting down, it helps less pull for warm start sometimes, but not always. (My friend suggested me to let the motor run a bit without connecting to fuel tank, so that less flooding).
The fuel pump, fuel filter, valve adjustment have been done last year.
As the diagram in boats.net, https://www.boats.net/catalog/honda...alj-1000001-to-balj-1099999/carburetor-manual
(1)should I replace item #2: float valve pin.
(2)should I replace item #11: starter valve set
(3) In terms of operation, I feel it is a guessing game for choke. For cold start, I choke on, it starts by 1 pull easily; For warm start, I leave choke off, it starts by 10+ pull. I understand the mix ratio of air and fuel in cold/warm temperature, but in practice, when sitting on the lake, it is hard to tell the temperature is suitable for cold or warm start, which require choke on or off. To avoid flooding in warm start, I firstly leave choke off (assuming warm temperature), pull 7-8 times. if it started, then bingo....if not, then choke on, pull another 2-3 times. Am I doing correct?
Attached is the pic of the motor. Any insights will be appreciated.
