Mercury 175EFI 2stroke '98 model. I got it for a customer because the power head looks brand new with a tag stated that is a remanufactured powerhead by Mercury. All parts numbers and date code are still there. Ran a compression check, spark tedt and gearcase inspection before purchased from an individual owner.
Installed a customer's boat, started engine in a barrel of water, motor sounds nice, rev up and quickly cool down. Customer ran a mile out alarms goes off. I asked customer to touch block. He said it's kinda hot. I changed new impeller, housing, gaskets, still running hot. I bypassed thermostats, still running hot. I reduced relief valve pressure, still running hot. I drill poppet valve passage thru the block, still runnimg hot, I poked thru exhaust at tail pipe, no change. I changed to another set of 2.5L heads and new head gaskets. Got it cool down and ran 1/4 mile farther but the alarm still goes off and the block feels pretty hot. Hotter than a normal temp. 24 years of fixing these things and I got this 2nd mysterious overheating situation. I am about to get the customer to approve me bypass oil injection system and mix his own gas next.
Has any of you here come across this situation? Please help share your advice and recommendation please please please!
I had the same Mariner motor with this situation and changimg the heads helped!
I need help please before I tear this baby apart and re rebuild it. How can Mercury's Remanufactured powerhead can be this bad???
Many thanks and regards and,
Best of wishes to yall!
