My 1st problem
ajp
"I've only been boating fo
"I've only been boating for 3 yrs and this is my first problem with the boat, i think i am doing well, The problem is that my mariner 75 (1996) will not rev past 2900 rpm no spluterring or spurting just a constant 2900 rpm, it was the first time in the water this yr, and i have changed the plugs and gas. Any ideas would be greatfully recieved, thanks."
"1. check for spark with a tim
"1. check for spark with a timing light on all cyl's
2. carb jet plugged, running with little or no fuel means no oil on that cyl
3 high speed stator, not familar with this engine, but possible, electric trouble shooting bottom left of page
http://www.marinepartsman.com/
I'm sure Graham will be along to help with this"
"You rang [img][/img]
Got m
"You rang
Got me diggin in the books on this one. Any chance you could post the serial number.
At first glance your model (if a 96) doesn't appear to have a "guardian" system on-board which would restrict the rpm's, so have to look elsewhere.
JB is correct that it has both high and low speed windings on the stator. But additionally, during this model run, Merc also played around with ADI and CDM ignitions as well as their normal Thunderbolts.
So need to determine first exactly what we have here to figure what to troubleshoot...."
