OK, having fixed the alternator issue and having run the used 318 in my driveway with a hose connected to it I decided to take the 24' lyman out for a test run. At 3300rpm the gps read 13 mph. The engine sounded as if it was running at 1500 rpm. I thought "no way is the tach right" but I got nervous running at 4000 rpm even though it seemed like it was running 2000 at the most. Also, the temp read 140-145 but I smelled a bit of burning rubber smell. I got nervous and put the boat away and went out on my 31 Tiara.
2 questions:
1. Tonight I see the tach is set at 6c. Should it not be at 8c for an 8 cylinder engine?
2. The engine has that silly(to me) 2 rubber impeller pump in one unit with no circulating pump. Is it possible that one impeller is shot? If 1 is bad would the other pump have enough pressure to keep the engine cool and is it possible that the part supplying water to the T stat is working but other parts of the engine are overheating? I could touch each exhast manifold without burning my hands by the way.
2 questions:
