I have 3 racor 500 filters.* Two of the filters provide fuel from the same tank to two seperare engines.* One engine is a 2 cyl Kubota the other is a 3 cyl Westerbeake.*
The Westerbeak application has just started creating a high suction pressure with engine cut out.* I have changed the 10micron*filter cartridge to no sucess.**When I open the racor to inspect the cartridge the fuel level is below the stand pipe supply hole.* The engine will run 1-2 hours after filter inspection then the cutout repeats.* I have inspected the tank hrough the 2" diameter leve gage port. No trash could be seen. I*drained the fuel and refilled through an external filter.* removed the ball check valve from the filter.**The problem is stiil present.*
The second application to the Kaboda engine from the same tank*has no problems.* The suction pipe location for the two applications is 6" apart.
I would appreciate any suggestions for the Westerbeake application.
