milling the heads 1997 Johnson 115
Is there anyone out there who knows the answer? I have a set of heads already cut .070 just wanted to know if they will work before I pull the original heads and find out it won't work for myself. I guess I'll get the answer and let everyone else know.
Had a customer try this on a 1999 115hp which is basically the same motor less 2 cylinders, and pistons hit the edge of combustion dome at WOT leaving a pretty ring around the piston tops. The pistons cleared at cranking and idle, rods/pistons just stretched at rpm. You may have to remachine the chamber dome..
