Hi guys, trying to get some help to why my piston started melting on #1 cylinder of my 84 60hp merc. Was running great then started throttling down and it lost power, after getting in home pulled plugs and found #1 plug was coated with aluminum, shined flash light in plug hole and the ridge that's on top of the piston has about a 1/2 spot where it has been ate out, also pulled exhaust cover to get better look, cylinder walls appear to be ok on all cylinders, 2 and 3 exhaust ports are pretty clean and #1 has a noticable amount of carbon build up on it. Motor always started and ran great, had one spot when coming up on plan that the motor would loose power but always pulled out of it
If anyone would have a idea on what might have caused this it be much appreciated, thanks
