Hello Everyone!
I recently purchased a boat with a 150hp XR6 Mercury engine. The engine ran fine until just a few days ago. I noticed when I first bought the boat, that the tach didn't work. I read online that this was due to the voltage regulator failing or being on its way out. I decided to swap the tach send from one regulator to the other and the tach worked fine... but it only worked for a few minutes and then quit!
The next day, I took the boat out to the lake and after I got on plane I went wide open trottle and got it up to 50-55 mph. The boat suddenly started losing power and I quickly put it in neutral fearing the worst. After a few seconds the engine died on its own. I tried to turn the boat over and I only heard a clicking noise.
After waiting for a few minutes... I tried to start the boat and it ran great at idle so I tried to get back on plane and stay at around 30 mph, but the boat did the same thing! It lost power and died! After this happened, the boat wouldn't start and I had to use the trolling motor to get back to land (2-3 miles away).
I checked the voltage gauge and the batteries were around 10-20% and when I checked them before heading out it had said 50-60%
While I was still at the lake I took the engine cover off and I noticed that the bendix on the starter was stuck up! I hit the starter a few times and got the starter to kick back down.
Once I got to the boat ramp I swapped out the battery with the trucks and tried to see if it was the batteries that were the problem. This did not help and the starter kicked up and started to turn the flywheel a little bit, but the boat would not turn over completely.
I wiggled the flywheel back and forth and got the Bendix to kick back down and I then tried to manually turn the flywheel. The engine however, wouldn't turn completely over. It would turn fine and then "hit" something and I would turn it around the other way and it would "hit" something again.
So my main questions are this.
1. Could the problem be electrical? If so, what should I check first? Is there a sensor that prevents the engine from turning over completely, even by hand?
2. Is it possible that the engine isn't turning over because the boat is still "stuck" in gear? By this I mean the boat may have "died" while in gear (I don't remember). If I put it in neutral with the boat "off" would the transmission still be engaged?
2. If the safety switch is in the "off" position, will the engine turn over as long as you turn the key?
3. When I first got the boat, you couldn't leave the engine in the "crank" position indefinitely. If the engine didn't start after a few seconds you would have to wait to try again. If I tried to turn the key to the "crank" position instantly after it didn't start, it wouldn't even click. Is this some sort of safety feature that might be preventing the engine from turning over completely?
4. Could my engine be done? I thought an engine wouldn't move even slightly in either direction if it was "seized" or had thrown a rod.
I appreciate any help I can get! Thank You!
