FstaRockr Burns
Hi all! so stator has just cooled off, ive successfully got 99% of the black plastic off it.. the blue wire broke off, and ground wire - but here is a pic of it:
can someone help me grasp how the windings work - yes, going to attempt to do this myself!
I take it the yellow think wires are the charging voltage.. they start winding at #1.. and stop at #8 - then they are extended to reach pole #11 to join with red and pole #12 to join with blue.
Now pole #11 (red winding) adds additional volts for high speed running, how would the two thin ends connect? The red was connected to the incoming yell, so it picks up from the volts generated by the yellow windings, and then I assume the thin windings add the supplemental power - how would these wires B1/B2, Y1/Y2 and R1 / R2 be connected?
The blue wire broke / melted off in the fire, but red stayed in tact.. it seems the thin wire was connected to the thick incoming yellow one and went to the #11 pole, after the #11 pole winding it went to the red wire to add the volts, and (split?) off to pole #12 where it did the same with blue wire -
