Mercury Outboard 150 Overheating
Keithh41
Motor keeps over heating, at 4000 rpm's temp hits 180 and goes into limp mode. Go to neutral and resets operates fine till it gets up to 4000. Replace water pump, thermostat, and temp sensor, still overheating. Any ideas would be most appreciated
We have a 2018 150 and at year 2 the motor started shaking and loss of power over idle speed. Tow it to basspro twice a yr since then with still no resolution. Changed thermostat, water pump, impeller, alternator…..
We argued for a new motor with no such luck but basspro still can’t figure it out .. ugh
Keith, we have the same situation going on. 2020, 150HP 4-Stroke, around 80hours same thing. Have done the same replacements as you. Have you found a solution? This is super annoying to be honest.
