west oz ian
gday from down under
, OK i have a 150 black max 1989 model with starting issues procedure is as follows had fuel pump rebuilt sweet but just as i thought still wont start when cold it will just keep on winding over till i flatten battery ,choke wont make a difference so i found that if i pull spark plugs squirt a bit of fuel in and put plugs back and try it then it starts pretty much straight away once started it would be OK for the day , would low compression play a part in this issue
compression on all pots is about 107 average any thoughts would be great
