Cumberland Mike
Hello, new to the forum and the world of outboards. I have a 2005 Merc 90 hp 2 stroke outboard that has always ran well until recently. It starts good and will take off running good for maybe 15-30 seconds running about 4000 rpms. Then it starts losing power and acts like it is starved for fuel. The rpm will surge and drop between 3000 and 4000.
Running 90 octane ethanol free boat gas.
I have replaced the fuel pump, filter, spark plugs, fuel line and pump up ball. When you pump the ball while running it helps a little but not much. I suspected bad gas so I ran the fuel line into a 1 gallon can of fresh gas...no change.
Tried gas drier and sea foam, idles better but no real improvements.
Checked compression, 90-95 psi on all three cylinders.
Starting to think electrical problem instead of fuel delivery.
Any thoughts?
Thanks, Mike
Any thoughts?
Thanks, Mike
