sprocket85
G'day, I have a merc 60 fourstroke 2011 that has an issue, I can idle all day fine, run on the plane all day fine, as soon as I get to trolling speed, 2000-2800 I can sit on these revs for a small amount of time until the engine starts to run rough as in no fuel pressure, I did get a bit of water in the tank awhile ago and the problem has persisted ever since, I changed fuel filters twice, cleaned the lines, drained the vapour separator, had the fuel pump apart. Maybe its a coincidence with the water in the fuel and maybe a sensor? When the problem first started I could quickly drop back to nutral give it a quick rev, drop it back into gear and it was fine for 15mins to 1 hour. Now when it starts its issue I turn the key off, and restart instantly and its good to go again.... I did notice the small water separator on the engine only appears to have a minute amount of fuel in it, Is this normal? When I pump th eprimer bulb it fills up then nearly empties, It only has this issue in gear under load. When the problem has started Ive tried pumping the primer bulb with no change, Only restarting the outboard seems to work now. No alarms sound, no beeps, no codes...... Thanks.
