Mechanically Declined
I've read old posts so thought I should comment on what I discovered today. Have a 2007 motor and have run premium fuel since new. Started idling and running rough and finally would not stay running. After replacing everything to the motor including the pickup tube in my tank (pontoon boat) that had become brittle and finally broke apart, I still had a problem idling with a loss of power. Would not stay running so started searching the threads on all of the sites. Changed the low pressure fuel pump and was pretty ticked that they couldn't design the latch for the motor cover so I would not have to remove it in order to pull the pump. Pump was not the problem. Then read about the "VST" (didn't know what it was until yesterday). Thought that might be the problem so I removed it, opened it up and it was clean as could be. My son noticed it looked dark in the inlet so I blew compressed air backwards and had little black particles blowing out. It was noticeably easier to blow air in so put it back together and installed. Was trying to figure out how to clear the fuel line just in case so decided to keep the electric high pressure fuel pump harness disconnected so it wouldn't run dry while letting the low pressure pump clear the line. Decided to give the primer squeeze bulb some pumps prior to anything else and got a line full of black particles (practically clogged the line) out of the hose and on the rag. It appears that the inside of the fuel line is disintegrating. I ran fuel through until clear and then hooked it up. Boat ran and was fine on a test run other than a little rough. Not sure if others are finding that the lines are not able to hold up but I will replace it with a hose that is resistant to ethanol fuels. I've had the same particles but not as much in my fuel filter so will look at that line as well. Was pleased that the stuff didn't enter the VST and create larger issues with the fuel injectors. This repair is not recommended unless you're a good backyard mechanic. Took some pics if someone wants to take a look (will try to attach if requested). Many thanks to the other posters that got my boat around the cove today.
