Hi all. I have a 1997 Mercury 30Jet. It pees at idle and low RPM. As soon a I throttle up to high RPM, water stream goes from solid stream to steam to non existent. The water pump has been replaced along with exhaust gasket and water tube intake gasket. I was told the woodruff key was replaced and looks good. The motor is set to the correct height as this was not an issue in the past - plus the boat has a tunnel. There is no thermostat on this model. No motor alarms are going off. Any suggestions at this point help.
