No its not backwardsBall is backwards?
I will check that, thank youAnti siphon valve at tank check ball stuck?
Thanks allFound the issue, can't even blow through it.
Nvm pic won't loadThis may help
Ok, ill try that,tyIt is not an anti siphon Valve. It is a pressure Valve. It does not allow pressure from the tank to reach the motor. But it will open with Vacuum. Throw it away they are garbage.
