olhardhead
My 1998 200 EFI has just shut down while running four times in the last six months sending water over the transom ...the whole nine yards...Exactly like the kill switch has been activated... All but one time it has been while running on step the last time a few days ago it was at idle. After this happens it will start again after it has been shut down for a period of time. I was thinking I had voltage regulator problems because the volt meter on my depth finder showed 16-17volts at times while running and the tach was not functioning properly. I replaced both regulators and the over voltage problem went away and the tach works as it should now. Two days ago the engine shut off while at idle and after fishing down the bank for an hour or so it started normally. I'm thinking new start switch and kill switch...each time this has happened it started normally after a length of time (in the storage shed). This engine has been recently overhauled and is on a Nitro Bass boat. The ignition switch is on the switch panel not on the throttle...Any ideas??
