A few months back I posted an issue with one of my 135 Opti's have low voltage. After crawling out from the aftermath of Irma, I'm finally getting back to troubleshooting the low voltage issue. Below is the data I've collected so far.
Boat has two, 2003 135 HP Opti's, three battery system, one for each motor and a center battery that can tie in all the batteries, isolate starboard and port from each other and tie in either the starboard or port engine to the center battery.
Batte
Original issue was low voltage on the starboard engine while running, ~ 11.7v at the gauge.
Voltage data collected on 11/10/18
Both engines off, battery switches on for each motor, center switch selected to "All"
Volts all three batteries - 12.1
Starboard engine running at idle, all switches selected "on" or "all"
Starboard battery volts - 11.95v
Center battery - 11.95v
Port battery - 11.95v
Gauge at console - 11.8v
Shut engine off, starboard battery on, center off and port battery off
Again starboard engine running
Starboard battery - 11.80v
Center battery - 12.1v
Port battery - 12.1
Starboard gauge - 11.7v
Starboard Alternator voltage - 11.72v
Slave solenoid - 11.72v
Shut starboard engine off, selected battery switches to "on" or "all"
Port engine running at idle speed
console gauge - 12.5
Starboard battery - 12.8v
Center - 12.8v
Port 12.8v
Alternator - 13.7
Port engine at 1000 rpm
Port gauge - 14.0v
Alternator volts - 14.31v
Starboard engine running at 1000 rpm
Starboard gauge - 11.9v
Alternator volts - 11.93v
sorry for long explanation. Any suggestions would be appreciated.
Angelo321
Batte
Port battery - 12.1
Center - 12.8v
Port 12.8v
Alternator - 13.7
Port gauge - 14.0v
Angelo321
