Mercruiser trim pump
Sucess
Hello, I have a 1983 3.0 140hp. On my trim pump there is an aluminum plate on the side of the motor with the solenoids mounted to it. What is this aluminum plate or bracket called? Where can I buy one? Is there a way around this plate? Thanks for your help.
Look for you drive on the parts part of the website here you need to know which pump you have oildyne, prestolite and if you have a metal or plastic reservoir. Take a look at what you have as given the age quite likely some one may have mixed and matched parts along the way
There is also a page where you can put your serial number in and it will directly go there. There are different serials for the engine, transom, and drive…click on boat engine parts in top left of page, then mercruiser sterndrive out serial in
