Mercruiser Stern Drive Service Manual
hd.alzd
Hi
Can anyone help me with Identifying the model of this sterndrive system from Mercruiser in order to find its service manual ?
there is just a serial number on it : B519406 Z
https://ibb.co/6PPsYz1
Based on the partial serial number (IF it is correct then it may be this below)
MERCRUISER : Alpha One SS 1986-1989, II SSM, III, III SSM, IIIA SSM, IV SSM, V SSM
Service manual # 6
What I will say, based on the trim ram design it is an older model.
Does it have a shift cable going to outdrive? If not then it could be a TRS drive. The predecessor to the Bravo. Shifting was controlled by a transmission. Drive was basically all time driven and no shift capabilities.
If you could spit outdrive from gimbal bell housing and snap a pic of the bell housing showing the shift cable assembly within the bell housing if present then that would make it much easier to identify
Most likely a TR or TRS with an aftermarket high performance lower gear unit.
Note the lower-to-upper unit six bolt pattern, the absence of a water pick up area and no thru prop exhaust outlet.
That's yer handy dandy Speedmaster #3. Racing unit. Not really for recreational use but if you like the straight thru transom exhaust noise, I guess it will make you happy.
Looks like it has a Latham Marine external steering ram and/or tie bar mount bolted to the back. Very "Miami Vice" all around. That prop tho...
These don't shift, you need a regular Velvet Drive (1:1 ratio) to shift it F-N-R.
Upper unit parts page:
http://www.marineengine.com/parts/m...one/driveshaft-housing-and-gear-assy-iiia-ssm
Lower unit Parts page:
http://www.marineengine.com/parts/m...none/gear-housing-assembly-propshaft-iiia-ssm
Transom plate:
http://www.marineengine.com/parts/m...995/all-thru-none/transom-plate-iii-iiia-iv-v
Twin driveshafts:
http://www.marineengine.com/parts/m...one/gear-housing-assembly-driveshaft-iiia-ssm
Gimbal:
http://www.marineengine.com/parts/m...al-housing-and-bell-housing-iiia-v-2nd-design
If you are hoping to install this on the back of a regular Alpha setup, you're in for an adventure.
