Mercruiser Rattling
codybb98
Any idea what this rattling noise is? It might be coming from something you can see in the video or it could be from somewhere else. I couldn't tell for sure.
Here's a photo
That motor should not be rocking around .coupler is around $350 USD
you need to remove the drive, lift up motor for access, R/R coupler, reinstall, realign,install drive
As BT mentions coupler is not too bad cost wise or amount of work wise. Only way it could get expensive is if a rotten transom and stringers contributed to misalignment which can take out a coupler. Check that good when you have the engine out
That fin on the drive probably contributed to the failure
I’ve never heard of this, I’ve heard of cracked cavitation plates where hydrofoils mount but never a coupler issue from them. Most couplers develop issues from improper engine alignment.
I’m curious of the correlation between a hydrofoil and coupler issues?
Harmonics
