I have a pre-alpha mercruiser outdrive and I believe it is stuck in the engine. I have removed the 6 bolts, the trim arms and the gear is in forward. I spent a good half of the day banging and hammering and trying to pry apart the outdrive with no luck... When the gear is in forward I got no separation, when in neutral, I was finally able to get about a 1/8" separation if and only if I had the outdrive turned to the left or right. If I had the outdrive straight, I got no separation. After a while I put the gear back in forward and the outdrive tightened back up and I couldn't get any separation. Any idea what is happening here? Do I have a much bigger problem than I was hoping for?
A little back story, I decided to pull the outdrive because I feel I have a bad vertical drive shaft. When the boat is in gear and I give it throttle, the propeller barely spins and can be stopped by a broom handle at full throttle. Maybe I'm wrong on this as well, but I thought I'd check it out...
