"A+B are the terminals on
"A+B are the terminals on top of the slave solenoid. A is red B is yel/red. I have a circuit breaker on the starter, which has 2 wires red/pur and ORNgoes to alt), The top breaker, in the box with solenoid aka slave 50A has 3 wires, red, red/pur and red.
the problem remains- no juice to the bottom harness. Nada, no gauges, no power going to top breaker, no fuel pump prime just quiet when turning the key on or start
When I bypass the starter breaker, everything works except the key start. But, I have a new starter breaker, which replaced the old breaker that was ok, but had the same problem.
When I jump A+B on the slave solenoid it fires right up.
I just went out and buttoned the dash back together. The heavy red that goes to the dash panel doesn't go through the harness. Battery>starter>front harness"
