Hello. This is my first thread so bear with me
I have a Mercruiser 350 5.7 liters V8 (1990-1995) with a Volvo penta outdrive 270 or 290.
I have made a full renovation of the engine with new head gaskets, and a lot of new parts.
After assembly of the engine I have run into a big problem.
The first test ride ended up stranding me on the ocean because the cooling hose blew.
After I changed the hose i have noticed that there isn't any flow in the seawater filter. The impeller works fine, as it pumps a good flow of seawater.
I have learned that there are something called a warm manifold system, and a cold manifold system. I believe I have the cold system.
https://www.perfprotech.com/blog/articles/marine-exhaust-tips
I have the gaskets with the restricted holes between the elbow and exhaust manifold. (worked fine before the renovation).
I have also tried to run freshwater from a hose through the system, but it won't "take it" through..
Does anyone have an idea of why the engine overheats and there is no flow of coolingwater?
Regards Mikael
Regards Mikael
