Nope, that just reveals a sh***y build. Stringers should no way collapse if the core goes bad. In the old days when glass hulls were first built, they OVER built them. Three layers of roving over the stringers ain't gonna fail. By the early 70's EVERYBODY was making molds and filling them with chop gunned layup and questionable quality control (minimum-wage employees with fiberglass rollers breathing polyester resin fumes all day...what a awful job) You see 2x8 lumberyard stock chop gunned or, worse, lightly tabbed to hulls. These cheesy hulls were never destined to last very long but there are still survivors out there. You gotta know what you're looking at. In almost every case of rotten stringers, the culprit is the lowly limber hole. These are cut in the stringer but left completely untreated and when the glass goes on, they end up with exposed wood down in the lowest part of the bilge. There they are year after year slowly suckin up water.
Nowadays hulls have structural liners and no more wooden stringers. Thank heavens. At least that's one thing less to worry about. You can move on to aluminum tanks embedded in foam, electrical wiring run in the bilge between the layers of hull and liner, poorly installed seacocks, etc.
